Helix All the button and knob not working not included fs
hinsjohn
Does anyone have this experience before? I just bought my helix 3days ago .Today I found that the knob and the setting button are not working but the footswitch are work when I play for a while .Once I restart the power I got stuck in Updating UI MCU page a long time , I need to shutdown and wait a few minutes to start again it will back to normal , but the same issue comeback  later.
When strange things start to happen the first thing to try is a factory reset.
Reset Options
Helix Floor/LT
Button Combination
Description
2
LED light Fun
3 & 4
Test Mode
5 & 6
Global reset
7 & 8
Reset setlists to factory, Keep IRs
8 & 9
Reset setlists to factory, Clear IRs
9 & 10
Reset setlists to factory, Global reset, Clear IRs
10 & 11
Upgrades existing presets to latest format
11 & 12
Clear current preset
5 & 12
Clear setlists, clear IRs, Return system settings to default
6 & 12
Safe boot mode
To use Reset Options:
  • Power off the Helix
  • Hold the desired button combination
  • Power on the Helix
  • Release the button combination
Please note: Buttons are numbered from top left to bottom right.
You said that you have only had the Helix LT for 3 days, and it’s not very clear if you have tried to update the firmware and it hasn’t completed successfully. If you were trying to update from a version of the firmware prior to v.2.80 you should know that there was a major change to the Core operating system in the Helix family of products at that time. During the Core change over it could look as if the hardware had encountered a “Boot Failure”.
O.K. Try this.
First restart your Helix LT while holding down FS9 & 10, then restart once more while holding down FS10 & 11, to see if that clears the fault.
If this doesn’t solve the problem I suggest that you restart the LT while holding down FS6 & 12 to put the hardware into “Safe Boot” mode and try to re-install the latest firmware again.
Note: it is a big help for us to know what computer and OS you are using when you are asking for assistance.
Hope this helps/makes sense.
