jsdehlers Posted November 26, 2021 Share Posted November 26, 2021 Hi, I have HX Stomp and have successfully connected the Mission Engineering TT-2 two switch box to add FS4 and FS5. Now, it's not working and may (not sure) be due to updates in the soft or firmware. Asking if anyone is having problems getting the ME box working. I have TRS cable from ME TT2 into the HX. I've confirmed correct global settings but what's weird is that when I insert the TRS cable into the HX the presets start scrolling. No way to stop it either than disconnecting the cable. I tested on another new HX unit a friend had with two different cables. Unfortunately, the same behavior so this seems something more than one bad unit. I've written to ME but no response. Anyone have a similar experience? And if so, any solution? Thanks. John Quote Link to comment Share on other sites More sharing options...
rd2rk Posted November 26, 2021 Share Posted November 26, 2021 I don't have one, but but when I was researching switch boxes I seem to recall reading that there were internal configuration switches. You might want to watch the use video on the Mission website. Quote Link to comment Share on other sites More sharing options...
jsdehlers Posted November 26, 2021 Author Share Posted November 26, 2021 Thanks for coming back on this question. You're right. Unscrewing the back plate there is a dip switch for TRS or TR referring to the cable connection to use. I have switch on TRS and using a TRS cable. I'm pretty sure it's not that as the problem seems to be in the HX Stomp unit. It will not recognize the footswitch on the TT-2 and when the cable it inserted into the FS4/FS5 port, the HX presets scroll one after the other. Quote Link to comment Share on other sites More sharing options...
rd2rk Posted November 26, 2021 Share Posted November 26, 2021 43 minutes ago, jsdehlers said: Thanks for coming back on this question. You're right. Unscrewing the back plate there is a dip switch for TRS or TR referring to the cable connection to use. I have switch on TRS and using a TRS cable. I'm pretty sure it's not that as the problem seems to be in the HX Stomp unit. It will not recognize the footswitch on the TT-2 and when the cable it inserted into the FS4/FS5 port, the HX presets scroll one after the other. My $20 Moskey Dual Switch works perfectly using TRS. I can't imagine that the much more expensive TT2 won't work. Are your settings: GLOBAL>Preferences: Exp/FS TIP = FS4 Exp/FS RING = FS5 GLOBAL>Footswitches: FS4 Function = Stomp 4 FS5 Function = Stomp 5 HX EDIT SETTINGS>Device Settings: FS4 Function = Stomp 4 FS5 Function = Stomp 5 Quote Link to comment Share on other sites More sharing options...
