kickinchicken Posted November 27, 2021 Share Posted November 27, 2021 I have two presets that both use delay. If I set the tap tempo on one and then switch to the other, I get the tempo that I had previously set on the second preset. Is there a way to get the tap tempo that I had set on the first to be inherited by the second? Quote Link to comment Share on other sites More sharing options...
SaschaFranck Posted November 27, 2021 Share Posted November 27, 2021 Global Settings > MIDI/Tempo > Tempo Select Set that to "Global". Quote Link to comment Share on other sites More sharing options...
theElevators Posted November 28, 2021 Share Posted November 28, 2021 Or touch the tap tempo button and select the setting you need. To me it’s a setting I don’t ever want to use since all my presets and snapshots are timed to our backing track. Quote Link to comment Share on other sites More sharing options...
kickinchicken Posted November 28, 2021 Author Share Posted November 28, 2021 11 hours ago, SaschaFranck said: Global Settings > MIDI/Tempo > Tempo Select Set that to "Global". Thank you! Quote Link to comment Share on other sites More sharing options...
kickinchicken Posted November 28, 2021 Author Share Posted November 28, 2021 5 hours ago, theElevators said: Or touch the tap tempo button and select the setting you need. To me it’s a setting I don’t ever want to use since all my presets and snapshots are timed to our backing track. Thanks! Makes sense. For me all my stuff centers around improv to some extent and I'll change presets depending on how I'm feeling so I want to make sure tap tempo won't change from preset to preset. Quote Link to comment Share on other sites More sharing options...
