MIKEY9966 Posted March 9, 2014 Share Posted March 9, 2014 Ok here we go again I have looked already but cant find any help, I really like my pod 500 its took some time to finger it out but it rocks, that being said I have pick up a zoom g 5 which is another Multi-Effects Processor . so I could add some new effects and maybe a stereo effect, I have tried guitar pod pod fx send zoom guitar in zoom outs pod fx return now I wanted to use the fx ( zoom) block on one amp and pod patch on other amp why wont it work any help would be grateful black star ht 5 krk 8 Quote Link to comment Share on other sites More sharing options...
NucleusX Posted March 9, 2014 Share Posted March 9, 2014 You have the option to either put the POD HD500 in series before, or after your Zoom G5. You also have the option to put the G5 into the HD500's FX Loop but not vice-versa, as the G5 does not have an FX loop. OR, you can split the signal just after the guitar and send to both inputs of the G5 and HD500 with a Y cable and then send your outputs from there into both amps front end input, or fx loop returns in on your amps. There are a few more exotic wiring approaches I could think of but Im not exactly sure of what your trying to achieve signal chain-wise. Keep in mind, you will have trade off's to make in all configurations. Like, where your mono and stereo lines are available for your chain(s). Quote Link to comment Share on other sites More sharing options...
MIKEY9966 Posted March 9, 2014 Author Share Posted March 9, 2014 I would like to put it in the pods effects loops but for some reason it wont work? I have guitar into pod pod fx send to zoom input zoom out put to pod fx return should work?? what would you do? Quote Link to comment Share on other sites More sharing options...
NucleusX Posted March 9, 2014 Share Posted March 9, 2014 Yes it should be possible. Guitar Output. > HD500 Input. > HD500 Mono FX Send. > G5 Input. > G5 Stereo Outputs. > HD500 Stereo FX Returns. > HD500 Outputs. > Amps. Then, you must assign an FX block in your HD500 to the FX loop and place it along your HD500's internal chain where you need it. I can imagine in that configuration, its going to be most useful with the FX loop block placed just before, or after the amp(s) or mixer in the HD500. Set all your levels to suit within the FX loop block Send and Return. Quote Link to comment Share on other sites More sharing options...
MIKEY9966 Posted March 9, 2014 Author Share Posted March 9, 2014 I will try I again tomorrow I must be missing something Quote Link to comment Share on other sites More sharing options...
MIKEY9966 Posted March 9, 2014 Author Share Posted March 9, 2014 ok got her up and running sounds kick lollipop, I guess you need both outs from the zoom going into the pod? I don't know be its up and running many thanks that's what I was looking for ,, maybe over kill for home use but ,, it sounds super good thanks Quote Link to comment Share on other sites More sharing options...
MIKEY9966 Posted March 9, 2014 Author Share Posted March 9, 2014 wait today I changed some cables to shorten things up, and it dose not work now ???? :( is there some setting in the pod what's going on I have spent a lot of time on this basic set up Quote Link to comment Share on other sites More sharing options...
stormstudios Posted March 9, 2014 Share Posted March 9, 2014 Did you fully comprehend this posted above? Then, you must assign an FX block in your HD500 to the FX loop and place it along your HD500's internal chain where you need it. I can imagine in that configuration, its going to be most useful with the FX loop block placed just before, or after the amp(s) or mixer in the HD500. Set all your levels to suit within the FX loop block Send and Return. Quote Link to comment Share on other sites More sharing options...
NucleusX Posted March 10, 2014 Share Posted March 10, 2014 If you intend on a mono send/return with the G5, then you should be sending the L (mono) send of the HD500 to the G5 input, and the G5 L (mono) output back to the HD500 L (mono) return. If your not getting any output from the HD500 to your amps in this config, then your problem will be somewhere in the internal settings of either G5 or HD500. There are many settings in both that this could be attributed to. Quote Link to comment Share on other sites More sharing options...
MIKEY9966 Posted March 10, 2014 Author Share Posted March 10, 2014 If you intend on a mono send/return with the G5, then you should be sending the L (mono) send of the HD500 to the G5 input, and the G5 L (mono) output back to the HD500 L (mono) return. If your not getting any output from the HD500 to your amps in this config, then your problem will be somewhere in the internal settings of either G5 or HD500. There are many settings in both that this could be attributed to. Sorry be a noob but what settings on the pod? I have it up and running sounds good, still trying to rack my head and see if there is a better way, but the zoom has no fx loop. It dose have one xlr output would that working going back into the zoom? Thanks Quote Link to comment Share on other sites More sharing options...
MIKEY9966 Posted March 10, 2014 Author Share Posted March 10, 2014 If you intend on a mono send/return with the G5, then you should be sending the L (mono) send of the HD500 to the G5 input, and the G5 L (mono) output back to the HD500 L (mono) return. If your not getting any output from the HD500 to your amps in this config, then your problem will be somewhere in the internal settings of either G5 or HD500. There are many settings in both that this could be attributed to. I would like to plug guitar into pod, and the zoom into the aux , now to do this the would have to have some kind of spliter the y cable did not work only one out put would, but 2 of may guitars paper and godin have 2 outputs, one being pizio pick up and, I have heard of a about spliter maybe this would work? But using the fx block for the zoom intowould pretty much be the same thanks Quote Link to comment Share on other sites More sharing options...
NucleusX Posted March 10, 2014 Share Posted March 10, 2014 This configuration is also possible. Mono to 2x Mono Y splitter cable. (no buffering) One end in the guitar, one end to the G5 Input, and the other to the HD500 Input. Stereo G5 Output, to the Aux Input on the HD500. There would not be a need for an FX loop block in this configuration and both the G5 and HD500 should be considered as 2 completely separated signal paths. Magnetic pickups are the prefered type. Quote Link to comment Share on other sites More sharing options...
