jbrown462 Posted December 6, 2021 Share Posted December 6, 2021 Greetings, I am currently in the process of building a pedal board around an HX Stomp XL. The goal is to have a set-up that can go direct to an amp (mono) or be able to use the line outs with cab modeling for recording in stereo. Would also like to use the HX as a midi controller for tempo and to assign expression pedal work to the delay and reverb pedals. Another goal would be to have some presets where the "right" input on the HX could take another instrument which would be handy for looping. Please have a look at the diagram I created and let me know if any issues with this signal chain jump out. I am curious if the looper should be in the send/return of the HX or if it should be last before output. Thanks for the help! Quote Link to comment Share on other sites More sharing options...
soundog Posted December 8, 2021 Share Posted December 8, 2021 I like it. The only thing I might do different would be to use a send and return for the looper. That way you can control where the looper gets it input (where you put the loop and return block in your chain). Then, of course, you're faced with mono vs stereo sends for the delay and reverb. 1 Quote Link to comment Share on other sites More sharing options...
PierM Posted December 9, 2021 Share Posted December 9, 2021 This is similar to my setup. Different pedals, but similar routing. Works just flawless. 1 Quote Link to comment Share on other sites More sharing options...
