Harald12 Posted December 12, 2021 Share Posted December 12, 2021 I have downloaded and installed Helix native as a 64-bit plugin in a 64-bit DAW: Reason 10 Intro, everything seems right but i got no sound. The meters in the Helix plugin dialog window does nt move, but the meters in the DAW move, for the track i have set up for my guitar. What can i do to get sound and effects and amp simulation from Helix native, and not just dry guitar sound? Quote Link to comment Share on other sites More sharing options...
datacommando Posted December 12, 2021 Share Posted December 12, 2021 3 hours ago, Harald12 said: I have downloaded and installed Helix native as a 64-bit plugin in a 64-bit DAW: Reason 10 Intro, everything seems right but i got no sound. The meters in the Helix plugin dialog window does nt move, but the meters in the DAW move, for the track i have set up for my guitar. What can i do to get sound and effects and amp simulation from Helix native, and not just dry guitar sound? Hi, I have not used Reason for many years, but I would first suggest the you check the connections on the rear of the Rack component inside Reason and make sure everything is wired up correctly for the audio in and out of the HX Native plug-in. Just like a real studio it is possible that a virtual patch cable is connected to the wrong socket. Hope this helps/makes sense. Quote Link to comment Share on other sites More sharing options...
