cubbini Posted December 13, 2021 Share Posted December 13, 2021 Line 6 50-04-0079-1 Jack Plate Assembly for Variax JTV-69 The Jack Plate Assembly for my Variax JTV-69 was damaged and I'd like to replace it, but they are a bit hard to find, even at Sweetwater. Will any of the other jtv jackplates work in the JTV69s? And - any tips on replacing this part? Thanks! Line 6 50-04-0079-1 Jack Plate Assembly for Variax JTV-69 Quote Link to comment Share on other sites More sharing options...
psarkissian Posted December 13, 2021 Share Posted December 13, 2021 " Will any of the other JTV jack plates work in theJTV69s? " --- No. That is why there is a dash 1, 2 and 3. 1) The curve of the plate is different, so the fit will be different. 2) the cable harness from the jacks to the main board are different lengths. 3) The ground leads in each version are different lengths. There's a bunch of product an parts on cargo ships (some 90+) off the California coast waiting to dock and unload. Check with Full Compass. Also, register your JTV-69 in your account, then check with Line 6 authorized service center to see if they can change one out for you. Quote Link to comment Share on other sites More sharing options...
cubbini Posted December 15, 2021 Author Share Posted December 15, 2021 Another question - Does the pickguard on the jtv69 have to come off in order to reveal the attach point of the other end of the green ground wire from the jack plate? Thanks....... Quote Link to comment Share on other sites More sharing options...
psarkissian Posted December 15, 2021 Share Posted December 15, 2021 No. It can be de-soldered from the from the circuit board side, then the green wire soldered to the same spot on the new jack plate. Be certain it all fits right. Quote Link to comment Share on other sites More sharing options...
savirlegna Posted January 2, 2025 Share Posted January 2, 2025 Buenas noches, se me ha roto el Conjunto de placa de conector para la guitarra Line 6 James Tyler Variax modelo JTV-89F, ¿alguien sabe dónde se puede comprar uno? 0F6962A3-348C-4E21-A72F-3D87B701DCEB.webp Quote Link to comment Share on other sites More sharing options...
psarkissian Posted January 2, 2025 Share Posted January 2, 2025 From Google translate,... "Good evening, my Line 6 James Tyler Variax JTV-89F guitar connector plate assembly is broken, does anyone know where I can buy one?" Check with the Lin 6 authorized service centers in your region,... https://line6.com/find/service_center/ There are five in your country. Quote Link to comment Share on other sites More sharing options...
savirlegna Posted January 15, 2025 Share Posted January 15, 2025 On 2/1/2025 at 22:31, psarkissian said: Del traductor de Google,... " Buenas noches, mi placa de conexión de guitarra Line 6 James Tyler Variax JTV-89F está rota, ¿alguien sabe dónde puedo comprar una ? " Consulte con los centros de servicio autorizados Lin 6 de su región,... https://line6.com/find/service_center/ Hay cinco en tu país. He Hablado con los cinco servicios autorizados de mi país y me dicen que la placa para la Variax JTV-89 está descatalogada y ya no se puede conseguir. Es posible que a los tres años de comprar una guitarra el servicio técnico oficial no encuentre recambios ? Quote Link to comment Share on other sites More sharing options...
psarkissian Posted January 15, 2025 Share Posted January 15, 2025 I will have to check when I get back to work. Office is closed til Monday, as the power is off due to the winds and fires in Los Angeles right now. Google translation,... Tendré que comprobarlo cuando vuelva al trabajo. La oficina está cerrada hasta el lunes, ya que no hay electricidad debido a los vientos y los incendios que hay en Los Ángeles en este momento. Quote Link to comment Share on other sites More sharing options...
