assigning amp drive setting to switch
thomhu
I would like to assign the "drive" knob of the amp simulator to a switch. Kind of like on a analogue setup where you would switch to channel 2 for a little more dirt.
Since I am not using the effects loop, in one of the factory presets I want to use that switch.  I go to the drive knob on the amp , push the button down, tell it to learn, and then press the switch. It asks for a range and I enter a number in the low and high boxes slightly higher than my clean sound. Then I tell it to replace instead of merge. However, when press the switch, I get no sound.
What am I doing wrong?
Is only a pedal assignable to amp drive and not a switch?
Thanks,
Thomas
