BRocks Posted December 21, 2021 Share Posted December 21, 2021 I really hope you guys can help me with this. I have been using a set of beyerdynamic DT770 pro 80ohm with the helix floor. All was working great. Just tried them there and the sounds is muffled distorted and glitchy. They work fine with other devices. I have no idea why they have just stopped working right with the helix Quote Link to comment Share on other sites More sharing options...
spaceatl Posted December 22, 2021 Share Posted December 22, 2021 14 hours ago, BRocks said: I really hope you guys can help me with this. I have been using a set of beyerdynamic DT770 pro 80ohm with the helix floor. All was working great. Just tried them there and the sounds is muffled distorted and glitchy. They work fine with other devices. I have no idea why they have just stopped working right with the helix Test if the headphone amp is bad....If you have a headphone amp, stick it on the main outputs of the helix and see if it remains...The Sony mdrCD3000 and mdr7506 I use are 63 ohms...a bit lower than yours...that usually means more trouble, but they have been fine for many years on a myriad of Line 6 gear. Quote Link to comment Share on other sites More sharing options...
PierM Posted December 22, 2021 Share Posted December 22, 2021 Also check settings in the Gloabals in/out-------->Headphones Monitor Try the various settings. I remember something similar when using Multi instead the exact output I wanted to hear. Quote Link to comment Share on other sites More sharing options...
