Line 6 Edit Win 11, Java version error, jre_setup won't download
Hi, New laptop with Win 11 installed. Line 6 Edit install fails to download jre_setup.exe for Java Runtime v1.6 32-bit.
Running Line 6 Edit even with the latest JRE 1.8 raises the error that JRE 1.6 32-bit is required.
This is to edit my Pod 2.0 which still has some great legacy tones but I need Edit to change values like noise gate threshold.
Does anyone have a solution for this, or an alternate method for controlling Pod 2.0?
This is why it's called the "bleeding edge". Sounds like you need to get a version of the Java Runtime module that is compatible with Windows 11. Even then, Line6 Edit may not be  compatible. Have you tried this link to the Windows 11 version of the Java JRE?  Install Java on Windows 11 - TestingDocs.com
When you open Line 6 Edit, it sends you to a download page presumably for your OS (IIRC your exact OS platform and version is sent to the web server in the http header). So I downloaded and installed that. It appears to be Win 11 compatible as I have another Java based app that runs on my new laptop, even though it's not exactly a spring chicken.
Checking for the version, I got this info:
java version "1.8.0_311"
Java(TM) SE Runtime Environment (build 1.8.0_311-b11)
Java HotSpot(TM) 64-Bit Server VM (build 25.311-b11, mixed mode)
Thanks for the link above, I followed the instructions and sadly not only did Line 6 still complain, the app that used to run stopped working. So I reversed everything, and things were as they were before.
Hi!
I'm glad there are people that still have a POD 2.0 in 2022. Like many, I've been frustrated with Line6 Edit and the state of POD support, so I started my own project: https://github.com/arteme/pod-ui/ It is still missing many feature I would like to see, but you can already control most POD features with it. Check out the Windows release at https://github.com/arteme/pod-ui/releases/tag/v0.2.0
HI, about a month ago, I re-installed the Line6 Edit software (after 15years of non use) on my lapop. I had to install an earlier Java version (Java SE 6) in order to get it to work. This is decribed in a post from atzions on Oktober 1, 2021. (thanks man !). maybe this info can help you with your W11 problem...
Very cool, I'm a developer and really should have done the same thing myself but am just too crushed for time. Looking forward to checking out your project.
I eventually figured the same thing out and created a separate post for this to help others - VERY weird that I didn't see the old post and I'm curious what keywords I missed!
