kanyfilm Posted February 6, 2022 Share Posted February 6, 2022 I am trying to use my M9 almost exclusively as a looping pedal and have run into an issue. I want to record loops and use my expression pedal as a volume control to control the loop volume. I have assigned the expression pedal to the FX slot where I have a volume control and it does work, however, since the M9 is at the end of my chain, the expression volume controls the ENTIRE SIGNAL I want to be able to just control the loop volume with the pedal and be able to play over the loop at any volume. I can't figure it out. Pre / Post doesn't seem to make any difference. Any thoughts? There is not a ton of info about using the M9 as a looper, I have been searching. thank you! Quote Link to comment Share on other sites More sharing options...
