HX Effects Stereo Outputs
JBussac
Hello,
In a stereo setup, I need to use mono effects on one side only. Let's say this last position reverb :
The only option I found is this one, but I have to use one normal output and one send output, that seems strange to me, with opposite pan. Nevertheless, the stereo effects works normally and this last reverb is only on one amp.
Is there a way to modify the outputs to set two "Main L/R" and then balanced them in their settings ?
Thanks a lot.
Move the first reverb to the other side of the split and set the Main L/R pan to Center.
Using the SEND for a Mono Out is normal, and the way it's usually done when sending to FOH and a stage amp/monitor.
