3.15 Update - Post - Snapshots/Bypass/Stomps not saving right...or just my own doing?
themetallikid
Ok, So I have this preset.....'Kitchen' that i've been working on as an all around, all-in-one sorta thing based around the SLO100 Clean/OD/Lead amps.   For whatever reason, either a bug or something I'm doing in the preset that I just cannot see....
Preset should be set up like this
Snapshot 1 - clean - Amp (1A path), dual cabs, reverb only
Snapshot 1 - grit - Amp (1A path), dual cabs, reverb only
Snapshot 1 - classic - EQ, Horizon Gate, Amp (1B path), dual cabs, reverb only
Snapshot 1 - crunch - EQ, Horizon Gate, Amp (1B path), dual cabs, reverb only
Snapshot 1 - rock - EQ, Horizon Gate, Amp (2B path), dual cabs, reverb only
Stomp 1 - country - Input Pad on, compressor on
Stomp 2 - chorus - Dimension chorus
Stomp 3 - boost - Minotaur
Stomp 5 - lead - TS808, Delay
Exp Pedal 1 - Wah - auto engage toe down (off position)
However, I am getting erratic behavior from the assignments on the Stomp switches.  Things are turned on/off backwards from their light, different blocks on the same stomp (1) are opposite each other.  I make corrections, resave the preset/snapshot and go to the next one and its the same but opposite behavior.  I correct it again, go back to the 1st snapshot and Im right back to what was there before saving.
I tried selecting a different preset, and then choosing this one again....same issue.
Either this is a bug with 3.15 or....there is something in the assigns that I"m missing.  Its feasible, this is the first time i'm combining the stomps/snapshots thing on a preset and using the snapshot bypass option.... so maybe its a known thing and i'm just discovering it?
Kitchen.hlx
I dont know, I noticed that the update procedure seemed 'different' to me.  and thats because I did not create a backup or factory reset AS THE NOTES SUGGESTED (insert face/palm high five here).  So I rolled back to 3.11, backed up last night.  This morning I reinstalled 3.15, but ran out of time before work to restore from backup and then check.  I'll resume that tonight....I'm sure its more user error.
I'll also reread those notes and see if it applies in anyway
Ok, after a proper reinstall, backup etc.....I'm left with the same issue, but not as erratic as before.  I think I had snapshot behavior opposite of what I prefer so it was discarding my changes unless I saved the preset.  However, I'm still having troubles with the Footswitch 1 button (attached to a comp and input pad).
I'm assuming that this, even though it can be assigned as global/on/off, is not something that CAN be assigned to a footswitch?  This could be related to one of the 'known issues' possibly....as it happens with the comp which is also a favorite block.  I tried just added a new one and got the same behavior.
I suppose I could just do the 'pad' with a gain block first in the chain....but I was liking the idea of one less block to add to my presets.  Here is the preset again....
Can someone verify or find my error (if its mine)?  Footswitches 1/2/3/5 are to engage the blocks as stomps (snapshot bypass) and the bottom row are snapshots.
Public service announcement...this preset isnt finished or properly leveled, but its close.  I just can't get past this issue before putting time into tweaking it further.
On seperate side note, I also have 3 favorites at the top of my list that have icons, but no names.  When I tried to add one of them, it told me there wasnt enough DSP....Is this new behavior that the favorites would be blacked out (no name) if there isnt dsp?
Kitchen.hlx
