dktreaster1990 Posted February 12, 2022 Share Posted February 12, 2022 I've been struggling with this issue ever since I started using my HX Stomp with both Cakewalk and Reaper. What I'm doing: Running the guitar into the right input on the HX stomp, sending signal through send and return blocks(an EQD Plumes Overdrive, Boss Metal-core, Boss HM-2W and Boss Noise Gate) and then sending that to a DAW via the only output option which I believe is "out 1/2". What I want to do: Take the wet signal (pedals engaged), send it to a track in reaper, and then apply an effect to that track (THU Randall T2 Clean). I want to monitor the end result (output from THU) only, no dry signal. I've tried monitoring from both the laptop (directsound) and the stomp ASIO. When I try monitoring on laptop, I don't hear anything. When I try monitoring through the Stomp, I only hear the stomp signal with pedals but not the output from THU. There also seems to be a very quiet "dry signal" I can hear if I turn the preset output volume on the stomp all the way down. I'm just trying to figure out what I need to change on the stomp and in Reaper's main/track settings to be able to use the Stomp for routing the pedals into the DAW, and the VST as the amplifier. Quote Link to comment Share on other sites More sharing options...
rd2rk Posted February 12, 2022 Share Posted February 12, 2022 Guitar>L/Mono IN>HXS FX (if any)>FX Loop L with External FX>HXS SPLIT A/B Routed 100% B>HX FX (if any) in Path B>HXS MIXER Block A and B Levels -60db (OFF) Reaper Track Input Mono 3, Record Monitoring AUTO, THU>Reaper Master Out 1/2>HXS Out 1/2 If you're using HXS Stereo FX or Stereo External FX in a Stereo FX Loop you'll use Reaper Track Input Stereo 3/4 Demo preset attached. dktreaster1990.hlx Quote Link to comment Share on other sites More sharing options...
