Split Path Output settings help needed
adagosto
I'm having problems getting the split path output settings correct. Reference page 25 of the Stomp XL manual. Its under "The Blocks" section. I can't get the "output Main L/R+ SEND L/R to appear.
But that's probably only part of my problem. What I'm trying to do it output my signal to effectively two amps. Well, its actually one amp that has two inputs. The Amp is a Vox AC30 and I'm trying to output one cable to the Normal channel and another output to the Top Boost channel. I'm thinking that I should be able to do this using the PAN L100 (for Normal channel) and PAN R100 (for TB channel). I think in order to do that I would need to add an additional cable from the Output R to the TB input on the amp.
Can someone explain how to cable up the Stomp and setup the path to direct the output signal to two different outputs?
Thanks!!
You don't explain why you want to use these two inputs on the amp?
The manual implies you need to split the signal into Path A and B, and change Path B to the Send's output instead of the Main.
But why are you trying to use the two inputs?
Thank you for the reply.
I have been trying to find a way to split the output signal into two identical paths but have the ability to switch from one to the other. Basically I just said...I need an A/B/Y switch.
But my post wasn't really all about that, it was simply, why can I not get the output path to look like the output path shown in the manual?
