NEW IMPROVED Helix MIDI (v3)
rd2rk
This is a Setlist containing 7 presets.
The first 6 Presets each call one of the 6 Catalyst Banks.
This demo was configured using the Catalyst Factory Presets.
The Stomp Mode switches are set up (ON/OFF) to reflect that.
As you create your own Catalyst Presets you'll need to set those up as required.
Stomp Mode contains 5 switches for Helix FX and 3 switches for Catalyst Boost, Effect and Reverb.
There's also 2 switches (snapshots) to select the Catalyst Channel.
This was created on a Helix Floor in 10 FS Stomp Mode and 8 Preset Preset Mode.
If you have an LT you'll lose the Channel Switches in Stomp Mode so you'll need to set Preset Mode to Snap/Preset to get those back.
The last preset calls MANUAL Mode and has a Snapshot that loads a Helix Amp and turns OFF the FX Loop.
I've deleted my original files. The more I used them the more "GOTCHA" type glitches I found.
This method is much more reliable (so far :-) )
Catalyst.hls
  • 2 months later...
I've got a couple of different presets I've been using, including a W/D/W that I use with my PC212.
The combination of Helix and Catalyst is really awesome.
FWIW - today I've driven my neighbor crazy by playing for like 3 hours using the Derailed Ingrid into the Cat poweramp.
Sounds GREAT!
