SteffenA Posted March 14, 2022 Share Posted March 14, 2022 Hi experts. I have an issue, as I will like to create two splits and two merges in one path in a Helix Rack preset. Is that possible? The first split and merge I need to make because I need to split only one channel from a stereo digital signal(and this seems to be the only wat to split only the left signal from a digital stereo signal), and the next split and merge because I want to be able to add som reverby delay to my signal, as a "send". please see the attached file. Quote Link to comment Share on other sites More sharing options...
bassbene Posted March 14, 2022 Share Posted March 14, 2022 Quote I have an issue, as I will like to create two splits and two merges in one path in a Helix Rack preset. Is that possible? As far as I know: No, not possible. Quote Link to comment Share on other sites More sharing options...
SteffenA Posted March 14, 2022 Author Share Posted March 14, 2022 Thanks, Bassbene. Do you know of any other way (with a module) of tapping only one channel from a stereo signal, and using it as a mono signal. Other than by using a split? Quote Link to comment Share on other sites More sharing options...
bassbene Posted March 16, 2022 Share Posted March 16, 2022 This should work with the Pan Block located under Volume/Pan -> Stereo. By going full left or right, you basically mute the other signal. Quote Link to comment Share on other sites More sharing options...
codamedia Posted March 16, 2022 Share Posted March 16, 2022 Unless I am missing something, that first split is actually redundant and not required. The 2nd split has to keep the left/right separate... so why not just use that as the split. EG: Stereo Input > Stereo EQ > SPLIT > (place volume on each path here) then continue on your existing chains. If the VOLUME is actually shared... just place a stereo volume block after the Stereo EQ then split. ANOTHER OPTION Why are you doing that first merge just to go through an EQ? Obviously that EQ is stereo.... you could just do away with that merge and place 1 mono EQ on each path. 1 Quote Link to comment Share on other sites More sharing options...
SteffenA Posted March 19, 2022 Author Share Posted March 19, 2022 Thank you for your reply, Bass and Coda. the first split and merge is only to filter out one channel form the stereo digital signal, and make it into a mono signal. And the only way I have found to do this, is to create a split. I would much prefer a block to do this. and my problem is that once I have created one split that whole horisontal line can not be used to anything else. Just to fill you in with my task. I want to use the Helix as a dual stereo vocal processor. and as there is not two balanced inputs, the best way to input the helix is by digital, so I will have one vocal on channel 1 (left) and another on channel 2(right). and I want to process them separately, both with two horisontal lines one used as a "send" the other as a direct processor, so I can not afford to use a whole line just for separating the channels. The first EQ is a generic EQ, that will not be automated by presets and snapshots. Quote Link to comment Share on other sites More sharing options...
