Jam_Sandwich Posted April 13, 2022 Share Posted April 13, 2022 Hi. I want to run my HX FX with all internal effects into the effects loop of my amp. I want to run the delay/reverb blocks in the loop specifically. My understanding is that to be in the loop the effects need to be in between the send/return blocks. But does the FX loop block do the same? And if so, does it mean that anything after the FX loop block is in the loop? Which of these would be the right way? Wah Block > OD Block > Chorus Block > FX Loop Block > Delay Block > Reverb Block OR Wah Block > OD Block > Chorus Block > Send Block > Delay Block > Reverb Block > Return Block Thank you. Quote Link to comment Share on other sites More sharing options...
MayPRS Posted April 13, 2022 Share Posted April 13, 2022 I use the HX Effects on 4 CM as well. I started with one of the factory presets which started with "4CM..." and add my blocks. These presets already have the "FX Loop" block added. Everything to the right of the block will be on amps FX Loop. Everything to the left will be on amps preamp. 1 1 Quote Link to comment Share on other sites More sharing options...
