ledvedder5150 Posted April 19, 2022 Share Posted April 19, 2022 Hey guys! I'm running my HXFX in 4cm, and it's been great with just my speaker cabinet. I'd also like to use its IR capabilities to send a 2nd output to the PA. I'm struggling with getting this setup, if it's even possible. Any help would be appreciated! Quote Link to comment Share on other sites More sharing options...
silverhead Posted April 20, 2022 Share Posted April 20, 2022 The HX FX has two Send/Return pairs. Obviously one is used for your 4CM setup. You can use the other to do what you want. Structure your preset to use a parallel path as described in the manual pages 36/37. Create the path split anywhere after the 4CM FX Loop and place the desired IR in the parallel path. Use the method described in the manual for Setting Path B’s Output to create the two Output blocks. This will route the Output of the path without the IR to the Main Outs, which will complete your 4CM setup, and will route the Output of the path with the IR to a Send output. Connect those to the PA. Notes: 1. You may need to adjust either the hardware connection you use for 4CM (switch to Send/Return 2) or the Output block routing in the parallel path. The above description may, by default, have a single Send/Return pair attempting to do double duty, which won’t work. Just make sure you keep the 4CM pair separate from the parallel path output. 2. if you’re using any stereo FX blocks after the IR using just the Send 1 connection to the PA may not sum a stereo signal to mono. Quote Link to comment Share on other sites More sharing options...
