joanesinu Posted June 9, 2022 Share Posted June 9, 2022 Hello, I received my new HX effects yesterday. I have a very rare problem with the ext amp channel switching feature. I have the Pedal 2 selected for external amp switching. Then, I assigned a footswitch in the command center for this function. The channel switching only works when I plug the cable into de HX Pedal 1 input. If I plug it in the Pedal 2 input nothing happens. What I am missing? I selected that in the first step already. Thank you very much. Quote Link to comment Share on other sites More sharing options...
rd2rk Posted June 9, 2022 Share Posted June 9, 2022 I don't have the HXFX, but I'm guessing that in CommandCenter you need to assign a FS or Snapshot to send the command to switch channels. IIRC you need to use a TRS cable and likely assign the command to "TIP", but that depends on the amp. Quote Link to comment Share on other sites More sharing options...
joanesinu Posted June 9, 2022 Author Share Posted June 9, 2022 On 6/9/2022 at 9:20 PM, rd2rk said: I don't have the HXFX, but I'm guessing that in CommandCenter you need to assign a FS or Snapshot to send the command to switch channels. IIRC you need to use a TRS cable and likely assign the command to "TIP", but that depends on the amp. Hi, I already done that. The switching works on the "EXP Pedal 1" input on the HX effects. The switching does not work on the "EXP Pedal 2", where I previously assigned the function. That's the problem, I choose the function for "EXP pedal 2" input but it's working when I plug the cable on "EXP pedal 1" input. No sense. Quote Link to comment Share on other sites More sharing options...
joanesinu Posted June 14, 2022 Author Share Posted June 14, 2022 I solved the problem. I had a wrong configuration. To use the EXP pedal 2 output the Ext Amp has to be on the options of "2 None" "2 (Tip)" "2 (Ring)" or "2 (T+R)". I was using the "1 (Tip)". So, the number on the config screen indicates the output or the EXP pedal output number. Thread closed. Quote Link to comment Share on other sites More sharing options...
