The_Twickerman Posted June 18, 2022 Share Posted June 18, 2022 Hi, another odd question from me.I am using the return as an auxiliary instrument. Unfortunately this means the tuner does not figure in the signal chain when selecting the return as the input. I don't suppose there is a way to the tune to post return? Ta gurus! - Nick. Quote Link to comment Share on other sites More sharing options...
silverhead Posted June 18, 2022 Share Posted June 18, 2022 Based in the manual it seems the tuner applies only to the Guitar input and is tapped before any processing. Quote Link to comment Share on other sites More sharing options...
The_Twickerman Posted June 18, 2022 Author Share Posted June 18, 2022 Indeed. As ever, I was looking for help because the answer isn't in the manual. I'm sure you right - but is there a hidden option? Probably not. - Nick. Quote Link to comment Share on other sites More sharing options...
silverhead Posted June 18, 2022 Share Posted June 18, 2022 There’s no hidden option. And the answer is in the manual by it’s absence. The full feature set is documented. If it ain’t documented it ain’t there. There’s no specific statement like “No, you can’t move the tuner in the signal chain and have it apply to the signal coming in from the Return jack.” But it doesn’t say you can - so you can’t. There’s an infinite number of things the POD Go can’t do. They’re not documented. Quote Link to comment Share on other sites More sharing options...
