coachz Posted July 3, 2022 Share Posted July 3, 2022 Can I please get a simple list that tells me which legacy effects are stereo or mono please? All I see in the manual is this. Legacy effects models vary in behavior: Legacy Distortion, Dynamics & Pitch/Synth effects are mono Legacy Modulation & Delay effects vary in that some are mono, some stereo, and some mono-in/stereo-out, where adjusting the effect’s Mix parameter can narrow the stereo image that is fed into them Legacy Filter and Reverb effects are stereo Quote Link to comment Share on other sites More sharing options...
datacommando Posted July 3, 2022 Share Posted July 3, 2022 On 7/3/2022 at 2:02 AM, coachz said: All I see in the manual is this. Looks to me like you have answered your own question. Legacy Distortion, Dynamics & Pitch/Synth effects are mono = MONO Legacy Filter and Reverb effects are stereo = STEREO Oh, yeah - then there are these. Legacy Modulation & Delay effects vary in that some are mono, some stereo, and some mono-in/stereo-out, where adjusting the effect’s Mix parameter can narrow the stereo image that is fed into them. Well, that is confusing to the point of what happens when you actually put one of these blocks into the signal flow, and checking what comes out of the other end. Possible one of three options, would be my guess. Surely, if you write down the result of the test you will have the concise information and the list you are looking for. I was really hoping that someone else would have written this reply for me, but dammit - no, I had to do it myself. Oh, I just checked the date - it isn’t April 1st. Wow! 1 Quote Link to comment Share on other sites More sharing options...
coachz Posted July 3, 2022 Author Share Posted July 3, 2022 Since I have the stomp connected to my Reaper DAW I'll just put a stereo analyzer on and see which ones are mono and which ones are not. It would have been nice though if there was an icon for legacy effects to indicate it Quote Link to comment Share on other sites More sharing options...
datacommando Posted July 3, 2022 Share Posted July 3, 2022 On 7/3/2022 at 1:46 PM, coachz said: It would have been nice though if there was an icon for legacy effects to indicate it Hi, It seems that Line 6 decided on the tiny Museum icon as a general indication of the status of Legacy effects. If you need a particular effect and want less DSP stress, then use a legacy block and in the midst of battle most people would not know the difference. Most anything that you would normally place in your signal path before an amp, should be mono, and after the amp stereo. Essentially what is quoted in the manual. Anything else is basically a question of using your ears. The majority of the legacy effects have had new Helix versions created that are far higher quality. Granted there are quite few legacy blocks that have not crossed over, as of the current date, but who know what v3.15 firmware holds that department. Admittedly, before the Legacy category of items were added to the Helix I would hook up my old POD HD500 to my Helix, simply to be able to use the Dimensions block. Now that is one item I would like to see benefit from a reworking to the new model standard. I would not hold my breath hoping that Line 6 coders decide to create new icons for stuff they seem to regard as museum pieces. 1 Quote Link to comment Share on other sites More sharing options...
coachz Posted July 3, 2022 Author Share Posted July 3, 2022 Thanks for the great replies. I really like the Dimension and Tri Chorus Legacy fx. The upgraded Stereo Trinity Chorus is great too. 1 Quote Link to comment Share on other sites More sharing options...
coachz Posted July 3, 2022 Author Share Posted July 3, 2022 After going through each Legacy effect I now know which are stereo and which are not. Some are simply Mono while others take Mono and make Stereo. I hope this helps others. You can test yourself with the attached preset. Just bypass the delay to test mono and enable it to test stereo and give a quick thwack to the guitar and mute it. Look at a goniometer and you can easily see what's mono and stereo. Legacy FX Mono -> Mono, Stereo -> Mono Distortion > Tube Drive Distortion > Screamer Distortion > Overdrive Distortion > Classic Dist Distortion > Heavy Dist Distortion > Colordrive Distortion > Buzz Saw Distortion > Facial Fuzz Distortion > Jumbo Fuzz Distortion > Fuzz Pi Distortion > Jet Fuzz Distortion > Line 6 Drive Distortion > Line 6 Distortion Distortion > Sub Oct Fuzz Distortion > Octave Fuzz Mono -> Mono, Stereo -> Mono Dynamics > Tube Comp Dynamics > Red Comp Dynamics > Blue Comp Dynamics > Blue Comp Treb Dynamics > Vetta Comp Dynamics > Vetta Juice Dynamics > Boost Comp Modulation > Pattern Tremolo Mono -> Mono, Stereo -> Stereo Modulation > Panner Mono -> Stereo, Stereo -> Stereo Modulation > Bias Tremolo Mono -> Stereo, Stereo -> Stereo Modulation > Opto Tremolo Mono -> Mono, Stereo -> Stereo Modulation > Script Phase Mono -> Mono, Stereo -> Stereo Modulation > Panned Phaser Mono -> Stereo, Stereo -> Stereo Modulation > Barberpole Mono -> Mono, Stereo -> Stereo Modulation > Dual Phaser Mono -> Stereo, Stereo -> Stereo Modulation > U-Vibe Mono -> Mono, Stereo -> Mono Modulation > Phaser Mono -> Stereo, Stereo -> Stereo Modulation > Pitch Vibrato Mono -> Mono, Stereo -> Mono Modulation > Dimension Mono -> Stereo, Stereo -> Stereo Modulation > Analog Chorus Mono -> Stereo, Stereo -> Stereo Modulation > Tri Chorus Mono -> Stereo, Stereo -> Stereo Modulation > Analog Flanger Mono -> Stereo, Stereo -> Stereo Modulation > Jet Flanger Mono -> Stereo, Stereo -> Stereo Modulation > AC Flanger Mono -> Mono, Stereo -> Stereo Modulation > 80A Flanger Mono -> Mono, Stereo -> Mono Modulation > Frequency Shift Mono -> Mono, Stereo -> Stereo Modulation > Ring Modulator Mono -> Stereo, Stereo -> Stereo Modulation > Rotary Drum Mono -> Stereo, Stereo -> Stereo Modulation > Rotary Drm/Horn Mono -> Stereo, Stereo -> Stereo Modulation > Tape Eater Mono -> Mono, Stereo -> Mono Modulation > Warble Matic Mono -> Mono, Stereo -> Mono Modulation > Randon S&H Mono -> Mono, Stereo -> Mono Modulation > Sweeper Mono -> Stereo, Stereo -> Stereo Delay > Ping Pong Mono -> Stereo, Stereo -> Stereo Delay > Dynamic Mono -> Mono, Stereo -> Stereo Delay > Stereo Mono -> Stereo, Stereo -> Stereo Delay > Digital Mono -> Mono, Stereo -> Stereo Delay > Dig w/ Mod Mono -> Mono, Stereo -> Stereo Delay > Reverse Mono -> Mono, Stereo -> Mono Delay > Lo Res Mono -> Mono, Stereo -> Stereo Delay > Tube Echo Mono -> Stereo, Stereo -> Stereo Delay > Tape Echo Mono -> Stereo, Stereo -> Stereo Delay > Sweep Echo Mono -> Mono, Stereo -> Stereo Delay > Echo Platter Mono -> Stereo, Stereo -> Stereo Delay > Analog Echo Mono -> Mono, Stereo -> Stereo Delay > Analog w/ Mod Mono -> Stereo, Stereo -> Stereo Delay > Auto-Volume Echo Mono -> Stereo, Stereo -> Stereo Delay > Multi-Head Mono -> Mono, Stereo -> Stereo Delay > Bubble Echo Mono -> Mono, Stereo -> Mono Delay > Phaze Eko Mono -> Mono, Stereo -> Mono Mono -> Mono Pitch/Synth > Bass Octaver Pitch/Synth > Smart Harmony Pitch/Synth > Octi Synth Pitch/Synth > Synth O Matic Pitch/Synth > Attack Synth Pitch/Synth > Synth String Pitch/Synth > Growler Pitch/Synth > Buzz Wave Pitch/Synth > Rez Synth Pitch/Synth > Seismik Synth Pitch/Synth > Analog Synth Pitch/Synth > Synth Lead Pitch/Synth > String Theory Pitch/Synth > Synth FX Pitch/Synth > Saturn 5 RingMod Pitch/Synth > Synth Harmony Pitch/Synth > Double Bass Filter > Voice Box Mono -> Mono, Stereo -> Mono Filter > V Tron Mono -> Mono, Stereo -> Mono Filter > Q Filter Mono -> Mono, Stereo -> Stereo Filter > Seeker Mono -> Mono, Stereo -> Stereo Filter > Obi Wah Mono -> Stereo, Stereo -> Stereo Filter > Tron Up Mono -> Mono, Stereo -> Stereo Filter > Tron Down Mono -> Mono, Stereo -> Stereo Filter > Throbber Mono -> Mono, Stereo -> Stereo Filter > Slow Filter Mono -> Mono, Stereo -> Stereo Filter > Spin Cycle Mono -> Stereo, Stereo -> Stereo Filter > Comet Trails Mono -> Stereo, Stereo -> Stereo Stereo Reverb > Plate Reverb > Room Reverb > Chamber Reverb > Hall Reverb > Echo Reverb > Tile Reverb > Cave Reverb > Ducking Reverb > Octo Reverb > 63 Spring Reverb > Spring Reverb > Particle Verb Mono Stereo Test.hlx 3 Quote Link to comment Share on other sites More sharing options...
datacommando Posted July 3, 2022 Share Posted July 3, 2022 On 7/3/2022 at 4:38 PM, coachz said: I hope this helps others. Ah, you see, now you have created a resource which could be very helpful to some other Helix product users - or even users of the older M units from where the Legacy effects were derived. Didn't take very long either - well done. 1 Quote Link to comment Share on other sites More sharing options...
coachz Posted July 3, 2022 Author Share Posted July 3, 2022 You guys help me tons so I'm glad to try to give back when I can !! Took about 40 mins only while rocking to Loverboy in the background. Lovin' every minute of it ! 1 Quote Link to comment Share on other sites More sharing options...
datacommando Posted July 3, 2022 Share Posted July 3, 2022 You never know - the guy behind helixhelp.com might add it to his comprehensive list of stuff. Yay! Quote Link to comment Share on other sites More sharing options...
coachz Posted July 3, 2022 Author Share Posted July 3, 2022 I would be honored ! Quote Link to comment Share on other sites More sharing options...
coachz Posted July 3, 2022 Author Share Posted July 3, 2022 Since these legacy fx have such a diverse range of routing it would be useful to have an indicator next to them in HX Edit such as one of these lines or images. MM MM/SM MM/MS MM/SS MS/SS Quote Link to comment Share on other sites More sharing options...
craiganderton Posted July 5, 2022 Share Posted July 5, 2022 That's great info! If you don't mind, I'll include your findings in version 1.2 of the Helix book, with appropriate credit of course. This also makes me think I need to cover Legacy effects in general, since the first two versions concentrated on the non-legacy effects. I also like your idea of the routing symbols, that makes a lot of sense. Quote Link to comment Share on other sites More sharing options...
coachz Posted July 5, 2022 Author Share Posted July 5, 2022 On 7/5/2022 at 11:09 AM, craiganderton said: That's great info! If you don't mind, I'll include your findings in version 1.2 of the Helix book, with appropriate credit of course. This also makes me think I need to cover Legacy effects in general, since the first two versions concentrated on the non-legacy effects. I also like your idea of the routing symbols, that makes a lot of sense. Thanks so much. It's my pleasure for you to use the info. Feel free to shoot me a link for a copy of the book too. :-). I've been following you for decades and remember so many of your articles including one that I thought was just so amazing. It was called "Things that keep you from making music" . Ring a bell? 1 Quote Link to comment Share on other sites More sharing options...
craiganderton Posted July 5, 2022 Share Posted July 5, 2022 On 7/5/2022 at 10:31 AM, coachz said: Thanks so much. It's my pleasure for you to use the info. Feel free to shoot me a link for a copy of the book too. :-) I can't figure out how to send a private message with this forum, so...send an email to the official support email for all my books, craig.tech.center@gmail.com. Tell me how you want to be credited, and where to send the link. On 7/5/2022 at 10:31 AM, coachz said: "Things that keep you from making music" . Ring a bell? I remember the title, but I have no idea what it said specifically, or where it appeared...after a few thousand articles, the details get blurry! Glad you liked it, though. Quote Link to comment Share on other sites More sharing options...
