boeg Posted July 21, 2022 Share Posted July 21, 2022 Hi So I like using the ratchet for a kinda background beat to jam to, but I was trying to make it more interesting and found out using it in combination with the glitch delay is just perfect. Only problem is that I only want the ratchets "output" to go into the glitch delay. The rest of my signal should not be "glitched", if that makes sense. I was trying to come up with a way to do it using splits, but I couldn't figure out how to get my desired result. Hope it makes sense. Sincerely, Chris Quote Link to comment Share on other sites More sharing options...
datacommando Posted July 21, 2022 Share Posted July 21, 2022 On 7/21/2022 at 7:53 PM, boeg said: I was trying to come up with a way to do it using splits, but I couldn't figure out how to get my desired result. Hope it makes sense. Hi, Save a lot of hassle and download the preset in this thread (link below) - it’s named “Boss RC 30.hlx. Once you have it in your Helix or HX Edit, add the Glitch Delay block on path 2B, behind the Send/Return block named “Boss RC 30” then immediately delete the S/R block. Next add a Ratchet block to replace the block you just deleted. Now you can change any/all the other blocks in the signal chain to suit what you want to do, and the guitar signal will be passed to the Ratchet-Glitch path 2B and through to the output while path 2A continues out un-glitched. Use this .hlx as a template to create as many variations as you like simply by moving things around. Hope this helps/makes sense. link: Quote Link to comment Share on other sites More sharing options...
