M9 Midi Folder change
PBabadoo
I've searched but not found a clear answer to this.
I want to use a midi pedal to just change the folders on my M9, then use the M9 switches to select a scene from within that folder.  In essence, the midi pedal becomes my "Bank up/Bank down" switch.  I can't get it to work correctly.  It gets "stuck" on a particular folder and the M9 switches usually choose scenes from the folder that I just left.
Is there a trick for this, or is it just not possible?
You can’t change folders with MIDI. You just select the preset directly by sending the MIDI PC associated with whatever scene you want. So if you were in Scene 3B in Folder 4 (PC#23) and wanted to go to Scene 3A in that same folder, you’d just send PC#22.
