Dummy cable in right output solves or creates a problem?
Indianrock2020
Some patch makers suggested a dummy cable in the right output to solve a "problem" with "left sum to mono."    But today somebody mentioned that once  a cable is plugged into the right output, the Helix won't sum left to mono and both outputs would get half of a stereo patch signal.   With the dummy cable, your PA might be getting half stereo ( missing info required for a reasonable FOH sound)
Deja vu...
No, a dummy cable plugged into the right side will not correct any mono summing.  You will be getting only the left side.
There is a bug in the Helix, all info is in the thread above.  Instead of a dummy cable, simply get a splitter cable.
If there is a consensus it seems to be that the Helix isn't going to know that the cable is a dummy cable so probably better off not putting that in there.... maybe you want to avoid things like ping Pong delays if you're going left mono out.... what I really want to find out is if I can take two mixer channels and send both left and right from the helix even though the mono PA is not going to treat those two channels any differently.
