Reascot Posted September 25, 2022 Share Posted September 25, 2022 I've been watching some videos about Variax guitars and hoped some of you could answer some questions for me. I'm looking for a way to have a -12 pitch on the two bottom strings (E and A) in order to create a fake bassist type sound. From the videos I have seen, I have only seen people do +12 settings, so I would like to know whether it is possible to do lower octave -12 settings. I think there is a mix function where I can have the original pitch of the E and A strings as well as the -12 pitch. Is this correct? And just to confirm, I can save this setting to the guitar and it will work with a standard 1/4 inch guitar cable into a normal guitar amp. I won't need to buy any further Line 6 products. Can anyone confirm this? Thanks. :) Quote Link to comment Share on other sites More sharing options...
silverhead Posted September 26, 2022 Share Posted September 26, 2022 Yes you can do that. I have used Workbench HD to create several bass guitar models which I store in the Custom bank on my JTV-59. I tune each of the bottom 4 strings to -12 and set the mix to 0% original and 100% alternate tuning. 1 Quote Link to comment Share on other sites More sharing options...
Reascot Posted September 26, 2022 Author Share Posted September 26, 2022 On 9/26/2022 at 9:33 PM, silverhead said: Yes you can do that. I have used Workbench HD to create several bass guitar models which I store in the Custom bank on my JTV-59. I tune each of the bottom 4 strings to -12 and set the mix to 0% original and 100% alternate tuning. Thanks for your reply. How good is the tracking when you lower the pitch? Does it work polyphonically or do they glitch if you play two strings together? Quote Link to comment Share on other sites More sharing options...
silverhead Posted September 26, 2022 Share Posted September 26, 2022 I'm not 100% sure but I would think it's polyphonic. Each string on the Variax has its own under-saddle piezo so the alternate tuning can be applied to the individual strings, which means polyphonic. The tracking seems fine to me but I'm not a bass player. I just use it for simple stuff on recordings so that I don't need to buy a bass guitar. For instance I can't speak to how it would perform with a slap-bass style. Probably not well, due mostly to the string gauge rather than the tunings. 1 Quote Link to comment Share on other sites More sharing options...
