Kuba7517511 Posted October 5, 2022 Share Posted October 5, 2022 Hello, I have a question about the Line6 Pod HD500X. I bought a used one and some time ago I noticed that I have the same amplifier twice, only one has the "pre" ending. What does it mean? First example Blackface Dbl Nrn - Blackface Dbl Nrn Pre Second example Brit J-800 - Brit J-800 Pre Solo-100 Overdrive - Solo-100 Overdrive Pre Blackface Dbl Nrm have AMP PARAMETERS Blackface Dbl Nrm Pre dont have this I am asking for help and advice which one is better Quote Link to comment Share on other sites More sharing options...
pianoguyy Posted October 6, 2022 Share Posted October 6, 2022 Have you read the owners' manual(s)? There are 4 (or more) of them. They are all available for download. Quote Link to comment Share on other sites More sharing options...
pianoguyy Posted October 6, 2022 Share Posted October 6, 2022 On 10/5/2022 at 9:41 AM, Kuba7517511 said: I am asking for help and advice which one is better Coke vs Pepsi Quote Link to comment Share on other sites More sharing options...
jakeman19 Posted October 9, 2022 Share Posted October 9, 2022 On 10/5/2022 at 7:41 AM, Kuba7517511 said: Hello, I have a question about the Line6 Pod HD500X. I bought a used one and some time ago I noticed that I have the same amplifier twice, only one has the "pre" ending. What does it mean? First example Blackface Dbl Nrn - Blackface Dbl Nrn Pre Second example Brit J-800 - Brit J-800 Pre Solo-100 Overdrive - Solo-100 Overdrive Pre Blackface Dbl Nrm have AMP PARAMETERS Blackface Dbl Nrm Pre dont have this I am asking for help and advice which one is better The "Pre" refers to it being used in conjunction with a DT series amplifier via L6 cable connection. So if you are using the POD stand alone without a DT amp, don't use the "Pre" models. FYI, I've never used my POD in 4 cable method (4CM) so not sure how that might work as I have a DT25. Jd Quote Link to comment Share on other sites More sharing options...
pianoguyy Posted October 10, 2022 Share Posted October 10, 2022 On 10/9/2022 at 11:04 AM, jakeman19 said: FYI, I've never used my POD in 4 cable method (4CM) so not sure how that might work as I have a DT25. ???? On 10/9/2022 at 11:04 AM, jakeman19 said: The "Pre" refers to it being used in conjunction with a DT series amplifier via L6 cable connection. What? On 10/9/2022 at 11:04 AM, jakeman19 said: So if you are using the POD stand alone without a DT amp, don't use the "Pre" models. WHAT! Quote Link to comment Share on other sites More sharing options...
jakeman19 Posted October 10, 2022 Share Posted October 10, 2022 On 10/9/2022 at 10:59 PM, pianoguyy said: What? From the Advanced Manual of the POD HD500x: Amp and Preamp Models We’ve included a complete set of “Preamp” versions of each Amp as well. Choose one of these to obtain the tone of just the preamp stage of the amp - recommended when feeding your POD HD500X output into an external amplifier, or when using the L6 LINKTM connection.* On 10/9/2022 at 10:59 PM, pianoguyy said: WHAT! See above for the explanation why or why not to use "PRE". On 10/9/2022 at 10:59 PM, pianoguyy said: ???? If you use the 4CM then you might want to use the "PRE" to use the modelled preamp of a specific amp to then go through the power amp section of the amp you are connecting the POD to. Jd Quote Link to comment Share on other sites More sharing options...
pianoguyy Posted October 10, 2022 Share Posted October 10, 2022 Which is much different than you said. Quote Link to comment Share on other sites More sharing options...
jakeman19 Posted October 10, 2022 Share Posted October 10, 2022 On 10/10/2022 at 11:41 AM, pianoguyy said: Which is much different than you said. It adds to what I posted. My post still is correct that you would use the Preamp Models with a DT amp, hence ".......or when using the L6 LINK™ connection.*" Jd Quote Link to comment Share on other sites More sharing options...
Kuba7517511 Posted October 12, 2022 Author Share Posted October 12, 2022 Thank you for answer! I use only PODHD500X + mikser So i should using amp without "Pre"?? Quote Link to comment Share on other sites More sharing options...
jakeman19 Posted October 12, 2022 Share Posted October 12, 2022 On 10/12/2022 at 6:13 AM, Kuba7517511 said: Thank you for answer! I use only PODHD500X + mikser So i should using amp without "Pre"?? Correct. Jd Quote Link to comment Share on other sites More sharing options...
