janwvdk Posted October 22, 2022 Share Posted October 22, 2022 Can I combine a Powercab 212 Plus and Powercab 112 Plus to create a stereo setup? Does this work well? Jan Willem Quote Link to comment Share on other sites More sharing options...
PaulTBaker Posted October 25, 2022 Share Posted October 25, 2022 I have that setup and use them with the 112 stacked on top of the 212. I have the 212 stereo width setting at about 150. I like it, however, I have never used a wet dry wet setup so I can't compare. I can say that I am very happy with this setup. I know this is not what you were asking.... I also look forward to read what others will say! Quote Link to comment Share on other sites More sharing options...
amsdenj Posted January 14, 2023 Share Posted January 14, 2023 I'll have to try it, but it seems like it should work similar to use two 112+s. That is, run Line6 Link into the 112+, and then Line6 Link out to the 212. Helix should treat this the same as two 112+ and send left to the 112+ and right to the 212. Not sure if it would work the same going into the 212 first. As for wet-dry-wet, this wouldn't be the preferred setup. The 112+ would be fine for the dry signal, but the 212 stereo wouldn't be able to be positioned well for ideal wet-dry-wet. I have done wet-dry-wet with two JBL EON10s positioned on either side of Powercab 112+. It sounds really great, but is not really practical or needed for gigs. 1 Quote Link to comment Share on other sites More sharing options...
