ruben23madrid Posted November 15, 2022 Share Posted November 15, 2022 Hello, I,ve updated the helix LT to 3.5 version but y don´t be able to see the new cabs or news. Hx edit was updated too. During the update process there was a reboot failure, but i saved that problem using helix update. Anyone wthit the same problem? Thanks a lot in advance. Quote Link to comment Share on other sites More sharing options...
SaschaFranck Posted November 16, 2022 Share Posted November 16, 2022 Does it really say 3.5 in the splash screen of the hardware and in HX Edits "about" menu? Also, can you see the new stuff on the hardware? Quote Link to comment Share on other sites More sharing options...
datacommando Posted November 16, 2022 Share Posted November 16, 2022 On 11/15/2022 at 5:57 PM, ruben23madrid said: Hello, I,ve updated the helix LT to 3.5 version but y don´t be able to see the new cabs or news. Hx edit was updated too. During the update process there was a reboot failure, but i saved that problem using helix update. Anyone wthit the same problem? Thanks a lot in advance. Hi, If you don’t see the new cabs and other features, you need to ensure that the version of HX Edit you are using is the latest v3.50. see this thread: Hope this helps/makes sense. Hola, Si no ve los nuevos cabs y otras características, debe asegurarse de que la versión de HX Edit que está utilizando sea la última v3.50. ver este hilo: Espero que esto ayude, tiene sentido. Quote Link to comment Share on other sites More sharing options...
ruben23madrid Posted November 16, 2022 Author Share Posted November 16, 2022 Ok thanks a lot, i will try again, removing firstable the old HX edit versions. 1 Quote Link to comment Share on other sites More sharing options...
