howlingmadcrazy Posted January 2, 2023 Share Posted January 2, 2023 I've recently started using my Firehawk 1500 again after it had been sat gathering dust for a while. However when I first turn it on I can only just about here it, but it's very faint and sounds awful. After maybe 30s the sound comes through as normal. If I switch it off for a couple of minutes and turn it on again the same thing happens but this time it will only take a few seconds to get up to full volume. So far once it gets up to normal volume it does seem to be stable. It was still at firmware 1.02, so I updated it to 1.30 today but it still has the same issue. Has anyone else had anything similar to this? Quote Link to comment Share on other sites More sharing options...
silverhead Posted January 2, 2023 Share Posted January 2, 2023 I would open a support ticket. Sounds like hardware. not firmware. Perhaps some component is starting to fail and taking a while to warm up to proper operating temperature. Quote Link to comment Share on other sites More sharing options...
Jermainekieffer Posted February 17, 2023 Share Posted February 17, 2023 It's possible that your Firehawk 1500 is experiencing a technical issue. There are a few things you can try to troubleshoot the problem: Check your connections: Make sure all of your cables are securely plugged in and that your instrument, speakers, and Firehawk are all properly connected. Reset the Firehawk 1500: Try performing a factory reset on your Firehawk 1500. Consult the user manual for instructions on how to do this. Check the speakers: Ensure that the speakers are in good condition and that there are no loose connections. If possible, try using a different set of speakers to see if the problem persists. Contact Line 6 Support: If the issue persists, contact Line 6 support for further assistance. They may be able to diagnose the problem and provide a solution. It's also worth noting that electronics can sometimes experience issues after being unused for a period of time. If the issue continues after trying the above steps, it may be worth taking your Firehawk 1500 to a technician for a more thorough check-up. TellCulvers Quote Link to comment Share on other sites More sharing options...
