Assign Output Main Out level change to a footswitch?
amasteve
What would be cool is to assign a footswitch to the Output Main Out, ie, if you have it set to say +5 db, hit the footswitch to change setting, ie, 10 db.  This would be the perfect clean boost.  Is it possible or even as a snapshot?  I have tried it and it doubles the output level, ie if set to 0, next setting 10, it changes to 20 when activating the footswitch.  I am obviously doing something wrong.  Thanks!
I use this all the time on my patches. Typically I swap the default fx loop fs2 for the main out clean post when the display shows 'level'. You have to remove the fx loop assignment first though.  I do this via Pod Go Edit which is quicker and easier than via Pod Go.
But here's another tip. If you add 2 momentary pedals you will have FS7/8. You can assign these to do most anything FS1/6 can do but these work in ANY mode. So you don't have to tap dance between preset, stomp and snapshot modes. If you set FS7 as your clean boost you can be in preset mode and still kick it in.
Unfortunately FS7/8 don't currently appear in the display but I'm hoping that Line 6 might give this option in a future firmware upgraďe.  Also, momentary pedals don't usually have Leds but even if you bought a unit that did it wouldn't help because the Led will alternate between being lit for on and off.
  • 2 weeks later...
