Correction/Clarification to my previous posts re: HF Trim and Speaker Mode
rd2rk
I have previously posted that the HF Trim is supposed to be OFF in Speaker Emulations.
I was wrong.
From the manual -
SPEAKER MODE PARAMETERS
Intended to respond like a real guitar speaker for a traditional "amp-in-the-room" experience. This mode applies different tonal characteristics of the selected speaker model to the system's coaxial driver, with the following adjustable parameters.
IOW - What makes a Speaker Mode sound like the speaker is the EQ applied TO THE COAXIAL (HF) Driver, NOT the LF Driver as I previously thought.
I've gone back and attempted to correct my previous posts, but may have missed some.
My apologies for any confusion I may have caused.
You weren't wrong, the HF compression driver is only on in Flat:FRFR and IR modes. It is not on in any Speaker mode, Flat:LF Flat or Flat:LF Raw. The manual may be a little incomplete and confusing in this area. I just tested using Powercab 212 and verified the tweeter is not on in Speaker mode.
