cs33956 Posted January 17, 2023 Share Posted January 17, 2023 !!SOLUTION!! I had an issue where my expression pedal stopped working. I reset to factory settings, ensured I was on the latest firmware, and checked settings. The pedal wouldn't toggle between EXP 1 & 2 and wouldn't register any input at all which was unlike any other issue I saw on the forums. I decided to take my pedal apart to see if I could find the issue and to my surprise and relief, the cable connecting the pedal to the board had become detached. Each connector appears to have glue holding it in the socket as opposed to a clip and in my case the glue had broken and the cable had detached. I've attached pictures below pointing out the cable to look for. I didn't think to take a picture before reattaching it and didn't want to risk detaching it again. I hope this helps someone in the future. **Note: I would recommend keeping track of which screw goes where when taking the pedal apart. A few are different sizes** 4 Quote Link to comment Share on other sites More sharing options...
soerenP Posted July 6, 2023 Share Posted July 6, 2023 I'm having similar problems, but here, the switching between Vol and Wah is still possible. I just don't see the respective change in values, when I move the pedal, even on factory presets. It's always at 100%. Any ideas? Any other than backup and factory reset? Is the optical sensor a system consisting of LED and phototransistor? Could the LED be broken? (I don't know why this seems more probable to me than a broken phototransistor, maybe because we all know broken light bulbs :D ) Would that mean 100% to the sensor? Quote Link to comment Share on other sites More sharing options...
soerenP Posted July 7, 2023 Share Posted July 7, 2023 Update: Factory Reset and Firmware "Update" (just aimlessly and desperately updating" from 1.40 to 1.40 ;) ) didn't work at all. Quote Link to comment Share on other sites More sharing options...
grdGo33 Posted July 7, 2023 Share Posted July 7, 2023 On 7/6/2023 at 6:16 AM, soerenP said: I'm having similar problems, but here, the switching between Vol and Wah is still possible. I just don't see the respective change in values, when I move the pedal, even on factory presets. It's always at 100%. Any ideas? Any other than backup and factory reset? Is the optical sensor a system consisting of LED and phototransistor? Could the LED be broken? (I don't know why this seems more probable to me than a broken phototransistor, maybe because we all know broken light bulbs :D ) Would that mean 100% to the sensor? Couldn't find anything specific on Go, helix LT seems to have a debug mode, but haven't seen anything for that for Go, you might want to try to contact support, or might try to see if you can fix things yourself like cs33956. This vid shows the LT, but the mechanics should be fairly similar? Yeah looks pretty similar looking at the pics above, I was curious to see how it work, looks like the small 2 white squares are 2 sensors, and in the case of Go, there's like a relatively big metal plate on top, on LT, it's a thin black metal, with some sort of white covering, ah, so one emits light, the other is a sensor. So yeah, if your LED is dead, replacing might be the only solution. If you're lucky could just be a detached cable! Quote Link to comment Share on other sites More sharing options...
shalfbeast Posted February 3, 2025 Share Posted February 3, 2025 I had exactly the same symptoms as CS33956 - the black cable connector wasn't fully down in the connector and the glue had gone hard and come off. Pushed the connector home and the expression pedal works again now. Thanks CS33956! Bit shoddy really - I bought the Pod Go in 2022, roughly a year later one of the black knobs started jittering without being touched. The shop replaced the unit for the one I have now. Roughly one year later the epression pedal cable hung off and the unit was only just over a year old. I think the robustness needs improving especially if it is ment to also be 'giggable'! Shame really as I really like it and its good value - having said that it should last longer than a year! Quote Link to comment Share on other sites More sharing options...
