ThomasLine6fr Posted January 19, 2023 Share Posted January 19, 2023 I'm trying to use the bass octaver FX so that I can record a bass line, some drums from an external source , and then add various guitar solos. The bass octaver works fine when I switch it on during a loop, but when I switch it off, whatever I have recorded with the octaver losses the octaver FX. Any idea ? Thanks Quote Link to comment Share on other sites More sharing options...
silverhead Posted January 19, 2023 Share Posted January 19, 2023 You don’t mention it but I assume you are using the Looper in the POD Go rather than an external looper pedal or a DAW for recording. Make sure the Octaver FX appears before the Looper in your signal chain. The Looper will record the signal entering it, including all FX blocks that appear before it. It cannot record any part of the signal that appears after it in the signal chain. 1 Quote Link to comment Share on other sites More sharing options...
