beaker3012 Posted February 26, 2023 Share Posted February 26, 2023 I've set up a preset with U2 Edge-like parallel delays. I would like to set up a footswitch to control both delays but can't figure out how to do that. Any help or direction would be awesome. Thanks! Duane Quote Link to comment Share on other sites More sharing options...
SaschaFranck Posted February 26, 2023 Share Posted February 26, 2023 Select block, hold footswitch, you'll be asked whether you'd like to assign it. Quote Link to comment Share on other sites More sharing options...
datacommando Posted February 26, 2023 Share Posted February 26, 2023 On 2/26/2023 at 3:37 AM, beaker3012 said: I've set up a preset with U2 Edge-like parallel delays. I would like to set up a footswitch to control both delays but can't figure out how to do that. Any help or direction would be awesome. Thanks! Duane Hi Duane, You didn’t mention which hardware device you’re using, but this relates to the Helix. As noted by @SaschaFranck in the post above, you need to select the first delay on the Home Screen and assign it to a Footswitch using the usual method of touching the required switch and when the dialogue appears select O.K. Now select your second delay block and touch the same footswitch that the first DDL is using, now when the dialogue appears this time use knob 3 (on Helix) where the option needs to be set to “Merge” (IIRC this is default) which allows you to add multiple effects the the same switch. The Scribble Strip above the switch should now read “Multiple2”. You can now use the customise feature to rename the switch to whatever you wish - eg: Parallel DDL. This is covered in the Helix 3.0 Owner’s Manual - Rev F - Pages 50/52 - Bypass Assign Hope this helps/makes sense. Quote Link to comment Share on other sites More sharing options...
