lou-kash Posted April 26, 2023 Share Posted April 26, 2023 The bad news: Autoupdate from within HX Edit may not work, it may display "No update available". This is not unexpected though, there are barely any apps whatsoever that still get any updates compatible with El Capitan (one noteworthy exception being the brilliant audio tagger Yate!) According to the Line 6 documentation, MacOS Sierra (10.12) or higher is "required". While that was already their message for earlier updates, this time it's apparently for real. The good news: HX Edit 3.60 can be installed manually and it still runs on El Capitan! The caveat: Firmware 3.60 is shown as "not available" via HX Edit 3.60 on El Capitan anyway. The workaround: Line 6 Updater may still very likely do the job on El Capitan directly, but I didn't test it. Instead, I booted my Mac from a Catalina (10.15.7) partition. The built-in updater then worked as expected from within HX Edit. The result: Back in El Capitan, HX Edit 3.60 can still manage my connected Stomp with firmware 3.60 as usual. Yay! :) Your mileage may vary. Quote Link to comment Share on other sites More sharing options...
datacommando Posted April 26, 2023 Share Posted April 26, 2023 (edited) On 4/26/2023 at 1:30 PM, lou-kash said: I booted my Mac from a Catalina (10.15.7) partition. The built-in updater then worked as expected from within HX Edit. Hi, I'm running Catalina (10.15.7) and my installed version of HX Edit detected the update and started to download the new HX Edit v3.6, but at about 70% it stopped and said it would launch a web browser for me to manually download the editor. I did that without issue and installed HX Edit 3.6 I opened up HX Edit 3.6 and once again the pop up said the new firmware was available, so I clicked on the green update now button. Once more it went into the downloading routine and then stopped with the message "HX Edit Failed to download firmware update file. Please check your internet connection and try again. Unknown Error. [code -2004]. First time I have ever had this happen, so will do a local install with the updater while disconnected from the local network and internet. Possibly a busy server issue, but never had this in over 7 years of updating. Strange! EDIT: Offline local install worked perfectly - up and running v3.6 Edited April 26, 2023 by datacommando Added note Quote Link to comment Share on other sites More sharing options...
lou-kash Posted April 26, 2023 Author Share Posted April 26, 2023 The good news #2: Helix Native v3.60 still runs on El Capitan, yay! Using Logic 10.3.3 here. Quote Link to comment Share on other sites More sharing options...
