mikeabbs67 Posted May 28, 2023 Share Posted May 28, 2023 My current setup is L(mono) to a Powercab 112+ and the 112+ to FOH. If I am using only mono blocks can I route my R main out to headrush frfr for use as a personal monitor wedge? In other words when everything in the chain is mono do the L and R main outs have identical signal? Quote Link to comment Share on other sites More sharing options...
rd2rk Posted May 28, 2023 Share Posted May 28, 2023 Main outs of what? Quote Link to comment Share on other sites More sharing options...
ricstudioc Posted May 28, 2023 Share Posted May 28, 2023 Assuming one of the bigger units - a)yeah, the signal is the same from mono to the L/R's. B) The way I always did it was to send XLR to the FOH, decoupled from the big volume knob - and the 1/4" to my stage frfr's controlled by that big knob. The house gets a constant send for the sound guy to handle, and you can jigger the stage level to suit your needs. 2 Quote Link to comment Share on other sites More sharing options...
mikeabbs67 Posted May 28, 2023 Author Share Posted May 28, 2023 On 5/28/2023 at 1:47 PM, rd2rk said: Main outs of what? HX stomp XL Quote Link to comment Share on other sites More sharing options...
rd2rk Posted May 28, 2023 Share Posted May 28, 2023 Take the L/Mono Out to your stage monitor. That gives you volume knob control of that. Place a CAB or IR Block on Path B and split the Path so that Path B uses Outputs 3/4. Take a 1/4" cable from the SEND Out to either the board (if close) or a DI Box (if over 20' away). That gives you a steady output to FOH. Example attached. mikeabbs67.hlx 1 Quote Link to comment Share on other sites More sharing options...
