Jessehendrixp1 Posted May 29, 2023 Share Posted May 29, 2023 well, pretty much what the title says.......... i sold my 500x so im trying to remove old line 6 stuff from my computer i dont need any longer. i try to use the l6 unistaller, but it doesnt show up there and it also doesnt show up in windows uninstaller either Quote Link to comment Share on other sites More sharing options...
hurghanico Posted May 29, 2023 Share Posted May 29, 2023 If HD500X Edit is not listed among the items that can be uninstalled using the Line 6 Uninstaller it means that the editor has not been installed properly for some reason. Sometimes the misuse of registry/system cleaners can erase data that should be kept instead. I suggest installing the editor again hoping that this time all the traces/logs necessary for the uninstaller to be able to remove everything will be recorded, so you can try again. _______________________________________________________________________________________________________________________________________________________________________ All about POD HD500/X help and useful tips Quote Link to comment Share on other sites More sharing options...
Jessehendrixp1 Posted May 29, 2023 Author Share Posted May 29, 2023 I actually tried that earlier im pretty sure but ill try to reinstall it again and see if that makes a difference Quote Link to comment Share on other sites More sharing options...
Jessehendrixp1 Posted May 30, 2023 Author Share Posted May 30, 2023 so i tried reinstalling everything and still hd edit never appeared........... what i ended up doing was just going through my program files and deleting them manually........ no any idea how to remove line 6 uninstaller? Quote Link to comment Share on other sites More sharing options...
moogary Posted May 30, 2023 Share Posted May 30, 2023 You can also try Revo Uninstaller ( https://www.revouninstaller.com / ). There is a free version that I have been using for years. You can also remove the Line 6 folder under Documents if you will never use it again. Quote Link to comment Share on other sites More sharing options...
Jessehendrixp1 Posted May 30, 2023 Author Share Posted May 30, 2023 Hey thanks ill give that a shot Quote Link to comment Share on other sites More sharing options...
