Variax 300 some models "modulating"
This could indicate one or more failing or dirty piezo pickups. First I would try loosening the strings and carefully removing any dust or grit from the pickups in the saddles. Simply blowing on them might work.
It could also simply be firmware corruption. Use the Variax Workbench program to save all your current models/presets. Then use Line 6 Monkey to reinstall the latest firmware, and then Workbench again to restore your saved models.
If the problem persists it’s likely that you’ll need to get the pickups replaced.
