stormbreaker367 Posted July 19, 2023 Share Posted July 19, 2023 I recently updated a preset I had made on Helix Native and when I moved it over to my Helix Floor model I wasn't getting any sound. I quickly found out that whenever I would adjust the expression pedal and then play a note the position on the volume block would jump from whatever it was at to 0. I have since factory reset the unit and tried loading backups and it is still doing this. Quote Link to comment Share on other sites More sharing options...
jiml6 Posted July 19, 2023 Share Posted July 19, 2023 On 7/18/2023 at 9:05 PM, stormbreaker367 said: I recently updated a preset I had made on Helix Native and when I moved it over to my Helix Floor model I wasn't getting any sound. I quickly found out that whenever I would adjust the expression pedal and then play a note the position on the volume block would jump from whatever it was at to 0. I have since factory reset the unit and tried loading backups and it is still doing this. Can you attach the preset? I'd be interested to take a look at that for you. Quote Link to comment Share on other sites More sharing options...
Schmalle Posted July 19, 2023 Share Posted July 19, 2023 When you look at the volume block's position parameter it's min/max indicators (white marks) are both on the left side (both set to zero so that you see only one mark)?! Quote Link to comment Share on other sites More sharing options...
