Driver cannot load on windows 11
EwanArm
I have the Pod Go Edit app on my laptop (windows 11) and everything works fine, but whenever I open it it comes up with this message.
Microsoft support says "See if an updated and compatible driver is available through Windows Update or from the driver manufacturer.", I can't find an update for the driver in my settings so I don't know if that is the issue or not. Microsoft's other suggestion is to turn off the Memory Integrity setting, which I am reluctant to do in case the driver (or any others I might install on my laptop with the setting disabled) have any negative effects on my laptop.
Looking at other forms it looks like the issue is just that Line 6 haven't updated the driver for windows 11.
I have a few questions;
1. what does this driver actually do and what does not having it loaded actually stop me from doing?
2. can I fix it?
3. what will happen if I do disable the memory integrity setting?
There are actually two drivers, I believe. One is a general USB device driver that allows your POD Go to be recognized as the computer’s soundcard for general audio as well as POD Go Edit I think, and the other is an ASIO driver to be used for DAW recording over USB.
Yeah, I think the one for the general USB and edit is working, just not the ASIO one
  • 4 months later...
Hi @Line6Tony, @Line6Pete1,
can you give us an update on this topic, will there (soon/ever) be a new driver for the POD Go / Win11?
I'm a bit disappointed, because the POD Go and its drivers are stated as "works with Windows 11" everywhere, without any asterisk:
Which is kind of a stretch if i have to disable a core security feature for the entire OS to use it for recording.
Thanks
  • 2 months later...
  • 8 months later...
