I don’t believe the Tap Tempo function can be controlled by an external pedal. It’s controlled by the Tap Temp switch on the top panel of the DL4.
You can, however, use the MIDI Tempo Sync feature as described in the manual.
I see a lengthy description of everything you can do with external footswitches on pg 14-17. However I don’t see any mention of being able to control the TapTempo feature using an external pedal/footswitch. Perhaps I’m missing it. Can you be more specific about exactly where you are seeing that?
