Pod Go power supply on the fritz!
Vics53
Does anyone know of a suitable power adapter that will work with a Pod Go other than the DC-3H adapter that comes with the unit?
I've got a new one on order but according to Sweetwater they may not be in until sometime in late October. The Line 6 store even shows this adapter as out of stock. I even called some local music stores. Nope.
The thin, outer insulation that leads into the small barrel-like portion of the adapter has frayed leaving the copper wiring exposed. Some of the wires have broken so this adapter is on limited borrowed time. If I bend and press the wires together just so, I can get it to work. But as soon as I move it with the slightest touch it looses its connection.
I've been looking but offhand I can't seem to find an adapter that will safely work with my Pod Go. Hoping someone here might know of something I can use until a new one arrives. I'm supposed to play at church on the 24th of this month. I'd sure hate to be up there and my signal goes out! So yeah, there's a bit of urgency here!
Input Voltage Range: 100-240V  AC, 50-60 Hz
Output Voltage: 9V DC
Output Amps: 3000 mA
Polarity: Sleeve: Positive, Tip/Center: Negative
Connectivity: 3mm x 5mm Barrel
Thanks in advance for any help.
Have a good day.
