boynigel Posted September 8, 2023 Share Posted September 8, 2023 I'm using my LT via 4cm with my Suhr PT15, and with an H90 in Effects Loop 2. I'd like to be able to add a Vox "edge of breakup" sound as a tonal option, but i don't want it going through the front of the PT15 as it doesn't sound very good that way (i've used preamp only models of Vox style amps into the effects return of different amps, and it sounds very good). Unless i'm overlooking something, i don't see any scenario, given my current setup, that doesn't end with a Vox model being combined with the front end of the PT15. Quote Link to comment Share on other sites More sharing options...
Schmalle Posted September 8, 2023 Share Posted September 8, 2023 cabling: guitar -> LT in left LT send 1 -> PT15 front PT send -> LT return 1 LT send 2 -> H90 in H90 out -> LT return 2 LT out left -> PT return Use fx loop 1 if you want the PT15 preamp. Don't use fx loop 1 if you use the vox amp model. Use fx loop 2 for H90. Quote Link to comment Share on other sites More sharing options...
boynigel Posted September 8, 2023 Author Share Posted September 8, 2023 On 9/8/2023 at 10:26 AM, Schmalle said: cabling: guitar -> LT in left LT send 1 -> PT15 front PT send -> LT return 1 LT send 2 -> H90 in H90 out -> LT return 2 LT out left -> PT return Use fx loop 1 if you want the PT15 preamp. Don't use fx loop 1 if you use the vox amp model. Use fx loop 2 for H90. I'll give that a try. thanks Quote Link to comment Share on other sites More sharing options...
