HX Somp/XL Using Snapshots while playing in Preset Mode
Adr1an0Adr1an0
Hello,
I had an AX8, and I was happy with it, but it was to bis und to heavy, with 2 Expressions Pedal .. giging in small bars, was a problem, my Pedal Board was about 80cm x 40cm  (31x 15 '')  ... with 3 Singers , 2 Guitars and a Basman, there is allways not enough place on the stage.
Thats why i have to get smaller.
I watches a lot of Videos on Youtube, but i still dont get it.
If i buy a HX Stomp/XL will my "wish" come true ?
I want to play in Preset mode. I can change the Bank by pressing FS1+2 simultainously.
When i'm in preset 1,  and stepp on FS1, can i Change, toggle, a Snapshot ?
I just want so play my presets/banks, und I need just for solos an Snapshot, with +3dB and some echo.
Is this possible with the Command Center ?
Thank you
If you are considering either the HX Stomp, or the HX Stomp XL, maybe you should have a read through the Ownwer's manual for the information you require.
HX Stomp XL - available here in English, French, Japanese and German:
https://line6.com/support/manuals/hxstompxl
Also the HX Stomp.
Hope this helps makes sense.
On 9/19/2023 at 7:23 PM, Adr1an0Adr1an0 said:
Hey, thank you for the answer.
Yes i red this pdfs,  but maybe I missed something.
Ah, O.K. - check this video from Steve Sterlacci which may answer your question about Command Centre. Steve has done lots of videos on this subject, so you might want to look at some of the others too.
Hope this helps/makes sense.
On 9/26/2023 at 1:10 PM, Adr1an0Adr1an0 said:
Hey, I saw this and many other videos, but no one can tell my if I can user Snapshots in preset mode ...
I have to simply try it out.
About 20 seconds into this video, Steve says that he uses this “Stomp” set up in preference to all the other options. He also says that you can configure the set up to chose other presets from one of the foot switches assigned in the Command Centre.
It’s a different approach to using Presets, Snapshots, etc., but it is worth considering this idea.
Hey,
I was focusing on the preset mode, but i think thatthe stomp mode could be a useful workaround
. But only with the Stomp XL. with 6 FS you can also switch the Bank.
With the HX Stomp (and only 3 Switches) , I could hook up an additional 2FS pedal, but then, I would lost the expression pedal.
I think, I will try out the Stomp XL.  I'm courious if can use the Stomp-Mode and while setting Footswitches to Banks and Presets like Steve.
Thx again.
On 9/28/2023 at 7:35 PM, Adr1an0Adr1an0 said:
I was focusing on the preset mode, but i think that the stomp mode could be a useful workaround.
Hi again,
Correct, and that was my point entirely.
You use Preset mode to select the preset you want to use (you don’t need to stay there), and once you have done that, you switch into stomp mode where you can turn on, or off, various effects as and when you need to use them.
Snapshot mode allows you to create “Presets within Presets”, and that will let you add a 3db boost and some echo to a single footswitch - no problem. Snapshots alllow you to control up to 64 different parameters within a Preset.
The advantage of the Command Centre is that you can essentially assign “whatever you want” to control “whatever you want” very easily.
I guess you might have being “overthinking” the whole thing. It’s quite easy really.
Hello,
I finally got my second Stomp XL, and this one works.
And yes, all the functions works as discussed here.  All only think that does not work, is, in Command Center, you can not assign "Bank Up/Down". But this is no Problem, with the Mode FS you can easily switch between the modes und get the Banks up and down.
It sounds great, its small, i have enough switches, i like it.
But, without the Updates, it would not be so cool. The stackable snapshots came Q3 2022, with the 3.15 Update. How could you survive so long without this update ? ^^
Ok, thanks again for all the help here in forum.
cya
