Sam_Pilsbury Posted September 23, 2023 Share Posted September 23, 2023 Hi all, Does anyone know what each segment either side of spot on on the HX Stomp fine tuner represents in cents? I believe the coarse tuning bar each segment is 10 cents. Someone said each segment on the fine tuner is 1 cent but I can’t find this post anymore nor verify this? Anyone know? Many thanks Sam Quote Link to comment Share on other sites More sharing options...
Schmalle Posted September 23, 2023 Share Posted September 23, 2023 You're right, it's 10cent/division. If you calculate the distance between 440Hz and 445Hz you get about 20cent. If you tune a note with Reference at 440Hz and then set to 445Hz it's two divisions off. Science, baby. Quote Link to comment Share on other sites More sharing options...
Sam_Pilsbury Posted September 24, 2023 Author Share Posted September 24, 2023 Thanks! What about the fine tuning bar? I’ve just seen a screenshot from the Helix where it says -3 and +3 to the left and right of the fine tuning bar respectively. Assuming this is the same on the stomp? (It doesn’t have the numbers) meaning 1 cent per division? Thanks Sam Quote Link to comment Share on other sites More sharing options...
Schmalle Posted September 24, 2023 Share Posted September 24, 2023 Yes, the fine tune bar is -3cent...+3cent. The >< indicators turn on/off at +-2cent and the footswitch LED changes from yellow to green at +-3cent. 1 Quote Link to comment Share on other sites More sharing options...
Sam_Pilsbury Posted September 24, 2023 Author Share Posted September 24, 2023 Thank you!!!! Quote Link to comment Share on other sites More sharing options...
PaulTBaker Posted September 26, 2023 Share Posted September 26, 2023 Well, i'd give you my 2 cents worth, but ...... :) Quote Link to comment Share on other sites More sharing options...
