USING PODHD500 WITH ABLETON LIVE
AleCintron
So this is my very first time trying to use ableton and plugging in the Line 5 PODHD500 into it. I'm trying to have it connect w USB directly into my PC. I dont know what I'm really doing. My drivers are up to date. Will this board even work directly into my computer? Any help and or guidance will be appreciated. Thanks in advance.
It should work as your audio interface via the USB connection assuming your drivers are correctly installed as you indicate. You might have to configure the Ableton program to recognize and use it. In Ableton, look for the area called Preferences, or Audio Settings, or something like that where you can specify that the HD500 and it’s ASIO driver should be used as the audio device.
