Feeding out put of Path A in the middle of Path B
sherimehmood
Hi Folks,
I had an situation the other day where I wanted to use one signal path (Path A) for my acoustic guitar and use the second one (Path B) for my microphone. This works great, however, when I put in a looper I can only put it on one path and not feed the output of the other path into the looper. I was wondering if its even possible to have both my Path A and Path B feed into a looper block, when each path is being fed by separate inputs. This is because I want the vocals and guitars to be processed differently but I want to add both of them to the same loop.
On 10/18/2023 at 9:56 PM, rd2rk said:
Place a SEND at the end of Path A and a RETURN at the end of Path B just before the Looper, and jumper the S/R jacks.
Attached is an example preset.
Wow didnt even think of that. But I am just a bit disappointed to see that they have not thought of a software solution for this one. Seems to be something other new hardware units are doing with software out of the box.
Thanks for your response though rd2rk
