BIASBASS Posted November 20, 2023 Share Posted November 20, 2023 Hi everone. I play both bass guitar and guitar in my band depending on the requirements. I like the sound choices of the bass cabs, amps and the guitar cabs and amps but is there a way to run both guitars into an HX Stomp so I can switch between the two with less hassle. Thanks in advance. Quote Link to comment Share on other sites More sharing options...
cruisinon2 Posted November 22, 2023 Share Posted November 22, 2023 On 11/20/2023 at 5:17 AM, BIASBASS said: Hi everone. I play both bass guitar and guitar in my band depending on the requirements. I like the sound choices of the bass cabs, amps and the guitar cabs and amps but is there a way to run both guitars into an HX Stomp so I can switch between the two with less hassle. Thanks in advance. Can't swing a dead cat without hitting an A/B box... pick your favorite, they all do the exact same thing. 1 Quote Link to comment Share on other sites More sharing options...
lou-kash Posted January 15, 2024 Share Posted January 15, 2024 On 11/20/2023 at 11:17 AM, BIASBASS said: is there a way to run both guitars into an HX Stomp Of course you can. You have two inputs. So you simply mute the input you don't need in the respective preset. 1 Quote Link to comment Share on other sites More sharing options...
lou-kash Posted January 16, 2024 Share Posted January 16, 2024 On the Stomp though, you may run into DSP limits if you want to have two different amps and cabs in one preset. So either you pick amps that aren't that DSP demanding, like the Del Sol 300 for bass and the Small Tweed or Jazz Rivet for guitar. (Been there done that.) Or you go with a "universal" amp that sounds great for both. For me it's the new "Dripman" aka Fender Bassman which sounds just brilliant. And yes, I play both bass and guitar through the Stomp, albeit not both at the same time in any of my bands. But also acoustic guitars and bass guitars together with an "electrified plank" as a bass drum stompbox. The HX Stomp can handle it all. Even vocal mics if needed… :) 1 Quote Link to comment Share on other sites More sharing options...
