mjmclane Posted December 7, 2023 Share Posted December 7, 2023 Ever going to consider making HX Stomp capable of hosting VST's? Sooner or later (probably in the works now) somebody is going to come out with a small box like the Stomp that will run any VST you want to put in it (like Mainstage for Apple). Quote Link to comment Share on other sites More sharing options...
SaschaFranck Posted December 7, 2023 Share Posted December 7, 2023 While the idea is great, it certainly won't happen with a device such as a Stomp. All programming issues aside (and these will already be enough, but still...): How are you going to manage a plugin with hundreds of parameters on that screen with 3 encoders only? 1 2 Quote Link to comment Share on other sites More sharing options...
datacommando Posted December 7, 2023 Share Posted December 7, 2023 On 12/7/2023 at 10:17 PM, mjmclane said: Ever going to consider making HX Stomp capable of hosting VST's? Sooner or later (probably in the works now) somebody is going to come out with a small box like the Stomp that will run any VST you want to put in it (like Mainstage for Apple). Hi, Sooner or later - hmm… it has already been done, but not with HX products, and I don’t think that will be happening anytime soon. Somebody has come out with a small box like the Stomp that can run plug-ins, you really need to check out the Dwarf from MOD Audio. Here ya go! https://mod.audio/dwarf/ Hope this helps makes sense. Quote Link to comment Share on other sites More sharing options...
SaschaFranck Posted December 8, 2023 Share Posted December 8, 2023 If I wanted to build a plugin-compatible rig, I'd either get a Macbook Air (or maybe a Mac Mini) and possibly think of something to remote controling it, so it never gets exposed on stage. The reason for using a Mac being that right now there's no more efficient computers around. Would however defenitely come with quite some additional costs, as you needed the software, a decent audio interface, a rack of some sorts and a controlling unit sitting on the floor. But others than that, it's very doable. And it'd be an incredible flexible setup, both soundwise but also from a utilitarian POV. 1 Quote Link to comment Share on other sites More sharing options...
